Slip Joint Clamp for Shift Linkage?
I'm wondering if anyone has or knows of a source for a U-bolt clamp type piece that is used on shift linkages. I want to bore and cut a slit in my shift rod and slip it over the solid rod it currently bolts to. Then I'll be able to rotate the whole linkage, and tighten it in place with the u-bolt clamp piece.
Currently my shift linkage has no adjustability side to side, all the joints are indexed with the rods to get the shifter in the right orientation. Due to the tight fit in the cockpit I need to have the ability to rotate the linkage to get the shifter in the right spot so my hand doesn't hit the body work when I'm in 3rd/4th gear.
I can always machine something, but it would be easier if there was something off the shelf. Thank you in advance
