Wheel size?
Anyone got a wheel handy? (Yes, I know they're 9x13 and 11x13.) What I need to know is the size of the center hole, the drive peg size, and patterns, etc.
The stuff that I can't seem to find ANYWHERE.
Anyone know off the top of their heads? Or can easily find?
Thanks!
No one knows?
What's the size of the center hole in the wheel?
What's the size, and pattern for the drive pins?
Frank, how precise do you need the numbers to be?
Roughly the center hole is 54mm
6 drive pins roughly 10.75mm diameter
Spacing of pins center to center 44.50mm
My micrometer battery is getting low and hard to read.
These numbers are from a old wheel center I had laying around in the garage.
Mark
The only one left that I need :
* I need the distance from center to center of the pins on opposite sides. (12 & 6 o'clock if you will).
THANKS FOR YOUR HELP!
-Frank
Frank,
89mm pin centers 12 and 6 O'clock position
Hope that helps.
Mark
what are you up to Frank?? Inquiring minds want to know...:p
