Access panel in floor pan under engine - ideas?
I've decided that I want to add an access panel so I can remove my engine's sump pan without removing the engine.
My desired goals are: easy to remove, will stay secure when in place and not have any fastener heads under the car.
Thus far, my ideas aren't thrilling me.
Has anyone done something similar, or have any suggestions? I'd like for it to be fairly flush (at least the leading edge), but don't feel it needs to be perfect. I have some sturdy rub blocks in the area (which could figure into the access panel's attachment method ...).
TIA.
I did the whole aviation route idea.
Using a doubler set with rivnuts.. 3 panels total.. in the end the bottom is perfectly flush. I can get a 4" access panel out for oil changes in minutes.. its perfect.
