New Formula B Chassis Update
Hi All
Just thought I'd jump in here and take the time to thank Tony for the long hours he spent working on the plug. He started on it just after the 1st of Jan...200 plus hours later here it is.
Our design criteria for the body was simple. Utilize the maximum ground effects and keep the frontal area to a minimum. We believe we have accomplished both. The bulge in the sides just aft of the radiator inlets are for my elbows. I have this thing about having elbow room. Also note how we blended the helmet into the engine cover...best aero. We went with a more conventional side pod....similar to an F3 which we thought was closer in speed and cornering G forces.
Tony has an extensive background in aerodynamics so making design changes was a no brainer.
Most of you wouldn't know this but Tony and I built most of the original body work for the DB1 (back in the day when we were a lot younger). Building molds is almost second nature to us....also built DB2 body work.
If anyone has questions please ask...we would happy to answer them.
Regards
Gary Hickman
