Gear position indicator and TRE
Just purchased what appears to be a nifty little device & wanted to let you Suzuki guys know about it (I posted the same thread on the SRN to see if any of them are currently using it)...
Its a GIpro by HealTech Electronics. Combo Gear indicator and TRE. Neat thing is that it learns the gears without driving the car (if needed). Just put it in each gear for a few seconds and bam. It does not calculate gear position with speed & rpm. The TRE also is adjustable- you can pick 4th, 5th or 6th gear maps. The display (1" lcd) auto-adjusts brightness depending on conditions or you can set it yourself. Last feature is an auto-on, off. The unit gets wired directly to the battery (well, and the gps) & does not have to be switched.
I figured for $150, what the heck. Better then constantly counting gears in my head! I'll provide a review after its installed and working (or not).
