Modified
#18329 FF GCR weight exception
The MAC has noted that the CRB has changed the weights of some of the cars which are eligible for Solo class CM. This implements a change to the minimum weights of certain cars which was not intended and is not considered desirable. In order to correct this oversight the MAC and SEB have provided the following Technical Bulletin:
Add in Appendix A, under class C Modified and renumber subsequent subsections,
as follows:
“Exceptions to the Club Racing GCR for all cars in this class:
1. Spec tire requirements do not apply.
2. Formula F (FF) minimum weight with driver:
Ford Cortina Engine: 1050 lbs.
Ford Kent and Honda Fit Engines: 1100 lbs.”
