Originally posted by Dave Hopple:
Pro-Werks tube adapters
Ken, these work great,(might be too big for the frt DB-1 Steering links) I built a full set of steering and push rods for my car using 4130 (.058)tubing, cut it to your required length and weld in the tube inserts LH hex, RH non hex, (it also helps you remember which one is LH when making adjustments on the rod ends) you can buy them at the http://www.chassisshop.com/
I'm suprised you can't find steel hex, any metal supply place should have at least mild steel. You could use tapped 6061 Aluminum (mill flats on the ends) tube for the frt steering links, I've seen guys use that on DB-1's -Dave
P.S. going to aero tube is my next project :D
