Best Trailer Type for Formula Mazda
i recently bought a 1998 Formula Mazda and need a trailer. Was thinking I would get an open, all aluminum, car hauler so that I could use it for other cars like spec miata and 4x4 off-road. What types of trailers would be easiest to load? Dovetail, onboard loading Ramps, etc.? Any insight is appreciated.
:greenflag:
Take a look at Kwikload.com
I purchased a rollback style trailer from Kwikload (their 18' internet special). Kwikload is right there your part of Texas. At the time, I was thinking that I would be in a heavier, tin top race car. I had a well-used truck and I knew I was buying a used racecar; I figured that I would at least get new trailer and eliminate one source of 'adventures'.
I added E-track to strap the car down around the wheels based on Moses' input and put on a $500 Superwinch. Winch power comes from the battery in my truck. With the nose cone off to strap on the frame for winching, clearance to the trailer is no issue. I have never bothered to try driving the FM onto the trailer for the simple fact that I believe it will roll back against engine compression. I have also hauled my S2000 (which I did just drive on and set the parking brake) and my K1500 short bed pick-up (when the transmission puked near Dallas thank you very much) with this trailer using the D-rings in the bed for tie downs.
A closed trailer for the FM would be nice if a haul through the weather is required. On my near term list is to solve that issue. At this point, reverting to closed box trailer is not on my list.
Thank you all for great input
Thank you all for your hospitality. Sure great to get this kind of help. I will look for an aluminum closed trailer and see what I can find. Happy holidays to all and I hope to see you all at an upcoming race.
