I need two metalastic engine/trans axle mounts for my Dulon LD9. 1 1/8 OD & 3/8 bolt hole. where is the place to get these.
If all else fails, you can modify leaf spring bushings. You should be able to find the correct ID. But the OD may need a sleve to fit.
I have done this with success.
See what McMaster-Carr has, as well as the Lord corporation.
Check Lee Chapman racing.
Bob L.
Google "urethane die springs" . 3/8 id x 1 1/8 odis a common size. Available in many lengths or stock tubes. Works great for
all different bushing applications. Just my $0.02.
john f
Dave Bean Engineering. I just ordered 2. BTW: Double check the i.d. I thought mine were 3/8 i.d. but they actually had a sleeze rusted into them and were 1/2 i.d.
http://www.antivibrationmethods.com/category/bushes
Hopefully they will ship across the pond.
https://www.kartek.com/parts/autofab...-716-bolt.html
They have an amazing selection of stuff - supply the off road industry
