Novarace Blade F600 for Sale SOLD!
I'm selling my Novarace Blade.
This is the sister car to the Blade that won the runoffs. Car is complete except the data system and the transponder will be removed. Car has less than 5 laps on track.
No expense was spared in the build of this car.
2011 Suzuki 600 GSXR with less than 3000 miles (engine hasn't been on track)
Novarace wet sump pan
2 qt. Accusump
Braille Lithium-Ion battery
Custom Fuel Safe fuel cell with molded in surge tank and internal Walbro fuel pump
Aeromotive Fuel filter
All fuel hoses are stainless steel braided hose with AN fittings
All coolant hose is silicon hose except for vent hose which is stainless braided hose with AN fittings
Custom aluminum crank case vent tank
Custom aluminum coolant tank
Professionally built car electrical harness
Professionally stripped engine harness
Cast SFI rated foam seat (not the cheap 2-part boat foam)
Brakeman calipers front and rear using all LD19 pads
Floating rotors
Momo Mod 12c open top steering wheel
Custom paddle shifter
Schroth Formula Car Harness with pull up adjustable lap belts
Custom built ballistic heat shield between block and header.
Ceramic coated exhaust from end to end
Extra front and rear sprockets (should be enough to set the car up for just about any track)
3 Sets of wheels
Asking $30K, but open to negotiate. Also open to trades. Considering FE or P2, but open to others. 704-604-5436
I'll post more photos when I get them. Car is currently located outside Atlanta.
https://goo.gl/photos/fHWnkB84aaM2Vu3DA
