Typical FE Dyno and Standard Gear Charts
One of the most common requests is for us to share typical dyno and the gear charts with the community:
Typical Dyno Curve:
http://sccaenterprises.com/tech%20bu...yno%20Perf.pdf
the 00's are missing from the RPM's. Don't get too hung up on the HP numbers, correction factors / altitude etc have an effect and we are not out to impress anyone. Our dyno is (according to Super Flow) being used with as much accuracy and repeatablity is any customer they have ever had...day to day matters...big numbers do not.
Gear "Sawtooth" chart:
http://sccaenterprises.com/tech%20bu...FE%20Gears.pdf
Pick your shift point (see dyno graph ;)) and draw the shift point drop down lines in to complete your sawtooth...(note the drop 3-4...hint hint...)
