7 Attachment(s)
SOLD Professionally Maintained 99 Formula Mazda SOLD
Professionally maintained and engineered by Eric Purcell at EFM Racing. Raced primarily in the Formula Car Challenge series and is consistently competitive at the front of the field. Car is turnkey as it was just prepped to run the full 2021 FCC season. Entire Package $21,000 and car is located on the West Coast. Contact Dutch at 949 554 9472 or dschultz@troyleedesigns.com
-Motec ADL 1 system with Pro Logging upgrade, 30 i/o and 2MB logging upgrade. New custom wiring harness built in 2020 to include wheel speed sensors (both sides), fuel pressure, front and rear brake pressure (brake bias as well), steering angle, 3 axis g’s, engine temps and pressures and GPS Beacon. Car is pre-wired and configured for Smarty Cam. Brand new Smarty Cam available for additional $1,500.00
-Strong running SCCA legal sealed motor. Strong recent compression test and oil injection delete kit. Recent muffler replacement. Nationally competitive engine
-Gear box completely rebuilt in 2020 including aluminum Rhino case, all REM treated gears, ring and pinion, shafts and dogs. Carrier rebuilt and dialed in by Scott Young Engineering.
-Rebuilt all shocks in 2020.
-Carb rebuilt in 20.
-Body work freshly painted
-Heavy duty A arms and updated hardware on all corners
-Fully wired for radios
- Tilton brake masters with remote reservoirs and calipers rebuilt in 2020
-Aluminum calipers with PFC pads
-Belts good until 2024
-Heavy duty radiator screens installed in 2020
Spares included:
-Brand new spare nose and wing assembly – Painted and fully assembled including end plates plus two additional new end plates
-1 extra set of BBS wheels mounted on used tires
-Custom Fitted Star Mazda Car Cover
-Brand new Ron Davis Radiator
-New spare set of PFC pads included
- Unused complete front upright rebuilt by Moses Smith
- 2 brand new wheel bearings
-Alignment bars included
-3 brand new heavy duty front control arms
-1 brand new rear control arm
-Multiple brand new jets
- New Facet fuel pump
- New hardware including heims, nut and bolt kits, several shear plates, skid plate, supertrapp plates, multiple new replacement chassis and body parts.
- Unused Fluidyne oil filter
- Muffler exhaust bend for sound
- 3 used mufflers
- Multiple Used gears and dog rings
- Multiple used parts in addition included
- Extra used set of tires with enough heat cycles left for full test day
https://www.apexspeed.com/forums/blo...8-e594f91fdf3f
https://www.apexspeed.com/forums/blo...e-90e125dcb0b0
https://www.apexspeed.com/forums/blo...8-4c3f162f02a6https://www.apexspeed.com/forums/att...id=97520&stc=1https://www.apexspeed.com/forums/att...id=97521&stc=1https://www.apexspeed.com/forums/att...id=97522&stc=1https://www.apexspeed.com/forums/att...id=97523&stc=1https://www.apexspeed.com/forums/att...id=97524&stc=1https://www.apexspeed.com/forums/att...id=97525&stc=1https://www.apexspeed.com/forums/att...id=97526&stc=1
https://www.apexspeed.com/forums/blo...c-d6279f9a3d3c
https://www.apexspeed.com/forums/blo...2-b22df6b14455
https://www.apexspeed.com/forums/blo...9-5a762800df3d
https://www.apexspeed.com/forums/blo...e-d7b8d6aa3b34
