Formula Mazda parts for sale
Trying to get rid of the last bits of my Formula Mazda inventory as I do early "spring cleaning" at the shop:
Bare standard frame, jigged, needs some paint touch-up in some spots: $1,000
"Tall Man" frame with front bulkhead, master cylinders, brake & clutch lines, partial shift linkage, interior sheet metal, AMB transponder, wiring harness & switch panel, steering column, stainless belly pan, inner radiator shrouds, oil & fuel lines. Also has SCCA logbook & chassis ID plate (serial # 00-200): used $2,000
Center cowl with mirrors, yellow, used in good condition: $300
2 Noses, used in good condition. One are yellow in good condition for $150, one is yellow/white & could use some repair on the lower front $100.
Engine cover, used in good condition. Yellow. $250
Rear lower shock mounts, 2 each left & right: $50 each.
1 Used rear hubs with drive pins, $200 each.
6 #5 shear plates, $12 each
Weber DCOE jets & other parts. Wide range of idle, air corrector, pump, and main jets as well as emuslifier tubes and various other small parts. Well over 100 pieces. $500
1 used outer rear wheel halves, $80 each
2 used inner wheel halves, $80 each
3 new front swaybar sliders, $26 each
5 aluminum front upper comp spacers, $4 each
5 front swaybar drop links, $15 each
4 front upright pin spacers, $3 each
2 shock spacers (3/8), $2 each
3/8 tapered spacer, $2
Used wheel centers, used and pin holes refurbished using the drill & press-in kits previously sold by MSR, 7 in the older style centers at $150 each, 6 newer style centers $200 each.
Front gurney material. One is enough for a single gurney & painted white, $4. Two more are enough for two gurneys each, $9 each.
5 front gurneys, trimmed for left side, one painted white & the rest plain, new $4 each
1 front gurney, trimmed for the right side, used & painted yellow, $2.
1 pieces rear gurney material, new & plain, $9 each.
Pair of left & right sideskins, in good condition, $140.
Oil injection pump with lines. Pump is good but one line is missing a banjo end. $100
2 intake manifolds, used, $180 each.
NEW complete DCOE carburetor with chokes, may need some setup, $600
Complete DCOE carburetor with chokes & air filter stack. This one was set up & running with our jet setup (the one that can actually idle for a while without fouling). $500
Used Facet fuel pump with weatherpack connector & AN adapters, $50.
Factory wiring harness (part # 080-112), new, $20.
2 shift fingers, one unused, one drilled for 5/16" bolt, $80 each.
6 short shock bump rubbers, $11 each.
Used engine spider with hardware, $140
Used fuel pressure regulator, $20
Pair of used Bosch blue coils, $60
Used clutch slave cylinder with adapter & mounting bracket, $50
3 #6 shear plates, $13 each
2 adjustable rev chips $15 each
Photos of all this stuff are available here: https://www.facebook.com/media/set/?...1&l=74d73e7163
Prices don't include shipping. You can also pick up at the shop or I can load them with me when I travel to the track.
