06 GSXR Clutch Replacement - Stohr
Howdy!
I think I blew the clutch on my Stohr yesterday. Works ok at low rpm but as soon as I jump car just revs up quickly. Happened very suddenly coming out of a corner. Gears still engage. When powered off in gear car doesn't move. Initally thought it was the diff that blew out but symptoms don't sound like it, and not sure what happens when you blow the diff, but first time I have had this issue.
I think I have to pull the engine based upon limited space. Any suggestions on the procedure and what to replace it with? This is my first try at this and I would prefer not to do it twice!
Any advice would be appreciated.
Thx
Cj
ctjahn@courtneyjahn.com
clutch replacement in WF-1
I have replaced my clutch twice without removing the engine in my WF-1. Little tight but very doable.
Sure sounds like a warn clutch...
Your description sure sounds like a warn out clutch. As previously mentioned, the stock components will suffice, and should be soaked in oil overnight. Wouldn't hurt to make sure nothing is binding up the clutch controls (cable, pedal). Let me know if you need a hand!
Jon Jeffords
Who rebuilds the diff? And Tips to remove
Ok, So after everyone volunteering their opinion it was the clutch I persisted on tearing the rear of the car apart and found all the bolts missing on one side of the Diff. ALL the bolts. Evidence of the other side having one bolt replaced (different style) So before I tear into this which is a bit different than my WF1 I had in the past and replaced the diff bearings....
1. Any suggestions for a FB diff removal?
2. Suggestions on a third party to rebuild it?
Thanks!
Cj
