How to sync autox runs in Aim RaceStudio2?
I'm at a loss...I've been trying to sync runs from the 2016 Nats in Aim RaceStudio2 but can't seem to find the right solution. I've read about using "GPS Lap Insert" to sync but that appears to assume/require that you're on a track where the start and finish points are the same (obviously not the case for autox)
I've also tried setting sectors on a track map but for some reason it is excluding several of the laps listed in the Lap Manager from my Split Report.
So, anyone know of a way to handle autox runs (distinct start and finish locations) in RaceStudio2? Or maybe an idea why some laps are being excluded from my Split Report?
Thanks in advance for any help!
David
AIM -> RaceCapture/Pro -> SoloStorm
Quote:
Originally Posted by
Barry Ott
Hey Mike, I didn't see AIM as a data source you support, is that right?
You could run SoloStorm off the AiM data, as long as you send it through RaceCapture/Pro first, right?
https://www.autosportlabs.com/produc...lemetry-cable/
https://www.autosportlabs.com/produc...acing-package/
