BMW 2002 Sedan 1600 1974 Offer?
Hello...this Beemer must go, our client just does not have room...period! Lowered to $15,000 [FONT=Cabin, Georgia, serif]make[/FONT] an offer. Good clean group 2 car, good build!!
[FONT=Cabin, Georgia, serif]Here is very clean and well-built BMW 2002~ Driver is retiring, this is so well priced for this quality! Not a garage queen, this was used last season![/FONT]
1974 BMW2002TRACK/RACE CAR #39 RED VIN # 4222447 -Fresh engine rebuild with receipts. 3-15 minute sessions @ CSRG Thunder HiH Nov. 34, 2023 - Two-45 DCOE weber carburetors - Pertronix Electronics/battery in trunk - New oilcooler Nov`23 - System 1 oil filter canister - New stahl header and Magnaflow stainless steel muffler - New left/right motor and transmission mounts - New driveshaft Guibo - Instruments-Tachometer with shift light, oil pressure and temp, water Temp, fuel pressure - Fire extinguisher system - Glass front/rear window/plexiglass rear side windows - Getrag4spwith short shift kit - 3.90limitedslipdiff - Vented disc brake front/rear - Bilstein shocks front/rear. Shortened Adjustable front struts - Eibach springs-front7" x400 lb./ rear8'' x350 lb. - Swaybarfront@25.5mm;rear@20mm. - Adjustable Rear subframe with solid mounts - 4-6"xl3 Panasports on 205/60xl3Toyo RR (4yrsold) - 4-6"xl3 Minilites(spares) - 12GalFuelsafefuelcell - Cobra racing seat - 5 pt racing belts(outdated) - All new fluids November, 2023 * Valvoline R1 racing 20-50 motor7 qts * Redline MTL transmission 2 qt * Reline 70-90 Differential 2 qt * Motul brake/clutch fluid.
$15,000 OBO RaceCarLocators
We're happy to set up the shipping logistics for you around the globe!
