Harness questions - they all have clips now
I'm harness shopping for the first time in a while and almost all that I find now fasten using clips. I've always bolted my lap and submarine belts to the frame and am hoping the collective Apex knowledge can answer some questions.
1. The clip harnesses either come with eye bolts or are available as harness accessories. So I mount the eye bolt where I used to mount the normal bolt and then clip the harness to it, right?
2. I have always mounted the lap and submarine harnesses together using a single bolt on each side. Is there a problem with using one eye bolt on each side?
3. Has anyone had problems with the eye bolt and clip mounting system in small formula cars with narrow cockpits?
I am also learning that I'm one of the few racers still wanting to use 3" harnesses, but I'll save that for a different post.
All feedback will be greatly appreciated!
Thanks, Cory
