I have an autocross car based off of a VD RF84. The steering rack is leaking, but seems to be tight. Does anyone know where I can get seals to do a quick rebuild/cleanup and re-seal?
Kenton Cabiness
Kenton Cabiness
post a couple of pictures
if it's like this one , I can walk you thru it
https://www.apexspeed.com/forums/att...d=110278&stc=1
Thanks Charlie. It's similar but a little different. Pics:
https://www.apexspeed.com/forums/att...d=110406&stc=1https://www.apexspeed.com/forums/att...d=110407&stc=1
get the id and od of the seals. Go to the local motion industries, Bearing Distributors Inc or whatever bearing house is local. They should be able to fix you up
the tricky part is disassembly
it's not obvious
That's a Jack Knight steering rack, my suggestion is send it for a rebuild, there are good vendors out there.
Keith Averill (closest to you)
Sean Kelly
Neil Porter
They all know their stuff and all 3 are on Apex.
