SCCA FM2 Run group - letter submission 26228
All –
If you are taking the time to read this thread, either currently OR at one point in time you had involvement with the Pro Formula Mazda (not to be confused with the PM18). Now that this particular car (either the Elan or Crawford tubbed cars) has been retired from MRTI and has arrived in the club racing scene with the SCCA, I petitioned the SCCA to start a joint class that includes the PFM that would be re-titled as FM2.
I am aware that currently the PFM is classed with FA, however I would like to separate this out in a manner consistent with how Formula Enterprise has evolved (FE and now FE2). In line with this thinking, I have proposed a class where FM (the original Formula Mazda) and FM2 (the Pro Formula Mazda) would be raced at the same time but as separate classes from regionals up to runoffs.
I’m aware that letter 26228 was discussed at the SCCA national meeting in Vegas in January and guidance that I was given was to spread the word and garner support IN WRITING to the SCCA for them to consider taking such an action.
REQUEST: If you reached this point in the thread, PLEASE take the time to write a letter of support to the SCCA requesting such a class. I believe that this will be a starting line to get the ball rolling and the next quest will be to get cars to the track.
Thank you in advance for entertaining this concept (please see below response that I received from the SCCA for the letter submission 26228) and should you write a letter of support for this request – THANKS!!
Best,
Ben Ditson
724-766-2178
Sent: Tuesday, January 8, 2019 10:01 AM
To: Ben Ditson <bditson@zoominternet.net>
Subject: SCCA Letter #26228 Update
Your letter has been reviewed by the Formula/Sports Racing Committee and sent to the Club Racing Board.
Here are your letter details:
Letter: #26228
Category: Formula/Sports Racing
Class: FM
Title: Request to introduce the PRO FM as FM2 class (similar to FE & FE2
Author's Request: This email should serve as a formal request to introduce an adjunct class to the current Formula Mazda which would be called the Formula Mazda 2 (FM2) class. The FM2 class would simply consist of those cars formerly run in the Mazda Road To Indy known as the Pro Formula Mazda (not the current PM18).These cars can come in 3 forms, Generation 1, Generation 2, & Generation 3 with the differences ranging from manufacturer of the tub to aerodynamics package through very minor (negligible) changes certain suspension components. The recommendation is that the class and car will continue to run the Mazda Renesis rotary motor with either the 4 port OR 6 port injector manifold. Engines will remain sealed units and this club series should allow for no less than 3 certified engine builders (Drummond, Mandeville, etc.). The gearbox will remain the Hewland FTR sequential gearbox with lever "stick" shift (no steering wheel mounted shift paddles). Fuel is and should remain 100 octane fuel with a need for 2oz/gallon of 2 cycle oil for lubrication per manufacturer recommendation. Tires should remain open with available compounds that can be provided by Cooper, Hoosier, Goodyear, Etc.Final consideration should be given to the ECM which is a Motec M400. For purposes of regulating the class, the latest map for the ECM for both 4 and 6 port manifolds should required. Engine output for these cars ends up being capped at ~270bhp.To restate, this is a formal request to open a new class called FM2 that will run with the FM class in SCCA club formula racing. With dwindling numbers in FM ranks and the arrival of the FM2 (previously the Pro Formula Mazda) into club racing. With approximately 140 cars in existence and 64 that are active, It should be reasonable to expect that fields of 10 (or more) cars are attainable on race weekends as well as at The Runoff's.Please feel free to call or email with any questions for which I can be of assistance.Best,Ben Ditson724-766-2178
