Greetings all
I will be running in the Vintage Festival at Mosport next month and have a 1988 Citation F2000. Does anyone know what gears to use?
Greetings all
Greetings All.
A quick question - can you use Hewland Gears in a Staffs Gearbox?
Thanks. Robert
When I last ran Mosport with a Pinto engine, Staffs gearbox and a 10/31 CWP, I used 19/32, 21/30, 23/28, 19/21.
If you have a recently built top of the line (long rods, etc.) Pinto, you might want to raise 2nd, 3rd & 4th one tooth.
Thanks Dave. I had the correct gear sets for first, second, third but I am off by a slight margin for fourth gear. Seeing I haven’t raced in 25 years I am confident that it will make an infinitesimal difference.
This is your 1988 car so I will send some pic from Mosport.
Many thanks for your reply!
Best Robert
Well, that's neat that you have one of my previous cars ! The 4th I ran (19/21) is no longer available. You'll have to use a 24/26, 25/27 or other similar gear. Good luck at Mosport. I loved that track, but haven't been there since 2011. As Sam Posey once said, it's a real test of one's "attachments."
I use:
First 18/32
Second 20/30
Third 22/28
Forth 25/27
https://youtu.be/pZgRFC8vvRk
