14 Attachment(s)
2013 Spectrum FF Honda
Up for sale is a well sorted FF car with a ton of spares
Motor built by Quicksilver to full legal spec with .020 over pistons
7 races on build
Data-
Motec with gps, rpm,mph, water temp, oil pressure and temp, break pressure, and wired for shock travel sensors.
Gearbox-
Built by Mark Baily in the UK
Diff and ring gear lightened by Williams
10:31 R&P
Comes with 9 gearsets
Car-
Car has been modified from factory to maximize lightness including:
6061 anodized aluminum floor epoxied and steel rivets. Custom anodized aluminum floor under the engine, Carbon fiber nose with honeycomb impregnated inside. Lithium ion battery(new 2021) Custom aluminum tripods, ceramic wheel bearings.
Car weighs 1112 lbs with 1/2 gallon of fuel and a 200lb driver
Current updates-
New main wiring wiring harness (2021) New engine harness (2021) New sub harness for the engine (2021) New rod ends and AN hardware (2021) New throttle cable (2021)
New oil and filter after the runoffs
belts good thru 2025
fire bottle recharged (2020)
Cal Club 2019/2020 FF champion
Car had one of the fastest trap speeds at the Indy runoffs.
Spares list-
Water pipe
Radiator
F upper a arms X2
RF lower a-arms X2
LF lower a-arms X1
R upper a-arms X3
RR lower a-arms x2
LR lower a-arms X3
F push rods X1
R pushrods X3
Steering rod X3
R roll bar link X3
F roll bar link X1
Roll bar clevis X1
Rear roll bar mount X2
Rear pushrod turnbuckle X3
front pushrod turnbuckle X 2
Steering pushrod turnbuckle X3
Rear upright clevis X2
Rear center crossmember X1
Rear center top block X1
Upper a-arm clevis X2
Rear lower a-arm clevis X2
Master cylinder spacer kit X1
Front Bell crank X2
Rear Bell crank X2
Steering rack clevis X1
Front thru bolt washer X1
Front thru bolt step washer X1
Front hub X1
Rear stub axle X1
Rear outer hub X1
Wheel pegs X4
Driveshaft tripod spring X2
Drive shaft axle X1
Tripods X2
Bellhousing studs X6
Front upright X2
RR upright X2
LR upright X2
rear brake rotors X3
Front brake rotors X2
CV boots X2
crush box X1
1 Aluminum and 1 steel floor under the engine
2 noses
1 shock cover
2 upper side pod tops
1 lower side pod
1Set of silver anodized Jongbloed wheels with mounted rains
Over $14,000 in spare parts
$57,000 for the car and all the spares
Please email, PM or call for any questions
Sean Kelly
sean1882@att.net
559-908-3092
2013 Spectrum ff Honda
Here are the remaining that i could not post before.
Please call or email for any questions
Sean
sean1882@att,net
2013 spectrum FF Honda
Will also consider selling the car separately for $47K
Please email or call for any questions
Sean
559-908-3092
sean1882@att.net
Pistons
Beautiful car!! Good luck with the sale.
The ad stated “motor built by Quicksilver to full legal spec with .020 over pistons” I read the 2021 GCR as only allowing Honda Fit OEM 0.25mm oversize. Did something change in the rules ? .020 generally refers to non metric system which is much larger than the .25mm (.0098) allowerd per the GCR. Asking for my own selfish needs.
Pistons
Hi Jim
Good question. That was the info given to us from quicksilver. Not sure if they meant 20mm or .020 over.
I can check with them to clarify.
Sean
2013 Spectrum
To clarify about the pistons.
PN 13020-RB7-Z00 pistons were used. OEM .25mm over
Thank You
Sean
The pedantic toolie in me can’t resist…
0.25mm = 0.0098”
2013 Spectrum Honda
Sale Pending.. Thanks Mike Scanlan for the help.
Sean
Car is sold.
Thank you apexspeed !!!!
Sean
Good deal!
Someone got a great car! Well done, Skelly!
2013 spectrum
Car is being picked up on wednesday and heading to IN. The car has enough spares to last the new owner many years,
Sean
Still Available?
Is this car still available?
Gone
