Sealing Tripod Joint Boots
Looking for guidance on how to seal the boot for the triangular tripod housing. We seem to always have some grease escaping from these boots. We are using the small air bleed tube on the axle side of the boot, to prevent air pressure from building up inside the boot, and are using the tie wraps with the small metal 'tooth' to provide a stronger grip. The boot is properly nested onto the hub, and the tie wrap is nested into its relief on the boot, but still the grease is leaking out; the round hubs on the trans are not leaking at all. I don't think we are using too much grease, but any guidance on that would be useful too. We are using pliers to tighten the tie wraps.
Any suggestions or tips would be greatly appreciated.
