15 Attachment(s)
2023 FRP1600 Championship Winning Piper DF05 For Sale
SOLD!!
Up for sale is the 2023 FRP F1600 Championship winning Piper DF05 car driven by Porter Aiken. It is a 2009 chassis and was converted to Honda in 2012. Yes, this is the car that was so fast they had to protest us because they thought we were cheating. (We were not) (1st time in FRP F1600 history that has happened). The engine is the much sought after O’Leary Honda engine that only has 3 weekends on it since a total rebuild. This engine was built with all brand new parts for the 2022 Runoffs at a cost of over $15,000. It has all the latest legal parts including the legal bigger pistons and the newly approved Fast Forward billet restrictor plate.
The car comes with the AIM Smartycam GP 2.2 84mm camera system, AIM MXL dash, AIM Evo4 data system, new Momo flat bottom 250mm steering wheel, Wilwood LD20 calipers, Dan Campbell custom air box and filter, custom Piper prepped steel wheel bearings, CF aero mirrors, Williams “Black” LD200 gearbox w/ 10:31 ring and pinion, O’Leary prepped Penske shocks, Hyperco spring perches, Schroth 2x2 Formula Harness w/ a 2027 expiration date.
The car was stripped to the bare chassis and sent back to Piper in 2020 where it was sandblasted to bare metal, confirmed straight, powder coated and a new SS floor installed. The car has been extensively massaged and upgraded by Dan Campbell and handles amazingly well and is extremely fast in a straight line. It has been recently dubbed the “Straight Line Special”. Own the car that dominated the 2023 FRP F1600 Pro Series with too many wins, poles, fastest laps, podiums and top 5’s to list.
The spares that come with this car are borderline ridiculous. I'm a little OCD at having everything that I could possibly need at the track. You will need a separate van to carry all the spares home. It is hard to put a value on the spares but the gears alone that come with the car would cost you over $14,000 to buy and the wheels would be over $10,000. You will not find a more complete package available that will give you the best chance to dominate in F1600. I will also give you all of our AIM data files, track gear selections and all in car videos that we have from over the years.
Asking a VERY fair $65,000 for a championship winning car and all spares listed below. (I'm sure I missed some) You cannot come close to duplicating this package for what I am asking. Call Marshall at 770-337-5458. Car and spares located in Canton, GA.
Here is a link to pictures of the car and most of the spares.
Piper DF05 & Spares Pics
SPARES THAT COME WITH THE CAR
2 spare noses
(1 needs small repair)
(1 brand new never used CF nose)
Custom mold for nose
2 spare shock covers
(1 needs repairs)
(1 used but ready to use)
1 rear diffuser
1 long exhaust
Engine cover for Kent Engine
(Great condition and can be converted to be used with Honda)
Chassis spider for Kent engine
Brand new L&R Upper side pods
Brand new L&R Lower side pods
2 custom long range radio antennas
2 new push to talk buttons
Custom Motorola radio harness (currently installed in car)
4 complete upright assemblies w/ rotors, drive pins and caliper brackets
Transport wheels
Fastrax camber/caster/toe fixture
Custom toe bars
5 total sets of wheels
(2 sets of Silver Fast Forward billet wheels)
(1 set of Black Fast Forward billet wheels)
(2 sets of silver Fast Forward lightweight 3 piece wheels)
6 set of used dry tires
(1 1/2 sets mounted)
(4 1/2 sets unmounted)
3 sets of used wet tires
(2 sets mounted)
(1 set unmounted)
35 Total Gear Sets
All gears are in great condition
12 1st gears:
14/36 15/30
15/30 16/29
16/30 17/29
17/30 17/35
18/27 18/33
19/32 20/32
23 Top Gears:
16/30 16/31 17/25
17/28 17/29 17/30
17/33 17/34 18/25
18/27 18/28 18/29
19/21 19/23 19/24
19/27 20/27 21/25
21/27 23/24 23/28
24/24 24/26
3 new dog rings
Custom LD200 Gear Change Tray
Full car set of New Hawk LD19
pads (not for this car but worth $)
New Hawk LD20 brake pads for 6 calipers
Good used Hawk brake pads for 2 calipers
2 spare good Wilwood LD20 calipers
1 Wilwood caliper o-ring kit (for pair of calipers)
1 new brake rotor
2 good used starters
1 new starter
1 new alternator
1 new alternator pulley
1 new Honda OEM clutch disc
1 new throw out bearing
1 like new throw out bearing
1 good used throw out bearing
1 used Evo4 data system (needs GPS lead repaired)
3 good used GPS sensors
1 new AIM steering sensor
4 good used good engine coils
2 good used engine sensors
1 new fuel pressure sensor
4 new oil filters
2 new custom push/pull throttle cables
2 new fuel pressure regulator rebuild kits
1 used custom Ron Davis Radiator
(not pretty but it will get you through a weekend)
1 used good Setrab oil cooler
1 original Honda throttle body restrictor w/ gaskets
1 new pair of CF flat lens mirrors
1 good CF Convex Mirror
4 used regular side mirrors
1 new in tank fuel filter
4 new fuel pumps
2 good used fuel pumps
1 new in line fuel filter
3 misc. used K&N air filters
Most of a brand new rear sway bar
1 new rear sway bar push/pull cable
4 brake caliper brackets
1 new billet steering rack
2 new steering rack clevis joints
2 used steering clevis
3 new rear lower arm mounts
New complete car set of all rod ends. (just ordered from Piper before last race)
4 misc. other new rod ends
Bag full of misc. used rod ends
5 misc. new spherical
Many misc. heim inserts
4 good used bell cranks
Full car set of new bell crank shims and bearings
Many spare various thickness camber shims
Misc. new suspension mounting brackets
5 new skid plates
2 new sway bar rods
4 new shock top collars
12 new front toe arm upright brackets (6 pairs - car requires 2 pairs)
Piper front 3rd spring assembly (we never ran this)
3 new original Piper front upper A arms
3 new original Piper rear upper A arms
1 new Campbell rear upper A arm
1 new Campbell upper A arm
2 new complete rear pushrod assemblies w/ rod ends
2 new bare rear pushrods
1 used complete rear pushrod assembly with rod ends
1 front used pushrod assembly w/ rod ends
1 front new pushrod assembly with rod ends
2 front new pushrods w/o rod ends
L&R new Front lower A arm assemblies w/ rod ends
L&R new Rear lower A arms
3 new steering arms
1 used rear axle
1 new rear axle
1 pair 250 springs
2 pair 300 springs
1 pair 350 springs
1 pair 400 springs
1 pair 450 springs
1 pair 500 springs
1 pair 550 springs
1 pair 600 springs
1 pair 650 springs
That's a VERY good price for an outstanding car
If I didn't already have a racecar I'd have been on that in a second.
